Fays2 Watts Link Special 11/10 -> 11/28/14 $659.99
Fays2 Watts link is normally $695.
Starting on Monday through the end of the month (work days anyway) we'll be offering the Watts links for $659.99
Available in either Red or Black powdercoat.
This is a proven, winning part. Multiple SCCA National Championships. Not a copy of someone else's design. The FIRST and most proven of the Gen 3 and 4 F-body Watts Links! They will fit both stock axles and axles with 3" axles tubes as well.
*PLEASE NOTE* that breather location on some aftermarket axles can vary and may have to be relocated. Also this does NOT work on Fabbed 9" housings.
Here's a video someone posted walking you around his (nice Strano springs too!). Looks like he opted to paint or recoat his a dull black, that's NOT the stock black which is Gloss. Also remember that Strano Performance rear sway bars #8410 and 8338 come with specific mounting bushings so you don't need the sway bar spacers he mentions.
http://www.stranoparts.com/partdetai...D=67&ModelID=7
__________________
Bumping this up as it's coming to an close shortly.... Don't miss out on the most proven Watts link for the F-body. Others might talk about making them, but this is here and been in use for years and it works.
__________________
No idea..... Wish I could tell you yes for sure but it's impossible to try every exhaust out there. And even harder as I don't think I've ever even worked on a car with that system.
__________________
Yes, because it's a single pipe over the axle/PHB/Watts link location.
Note that it might fit some "true duals" but no car came stock with duals in that location, and few cars have Watts links. So no company making true duals would have done anything but make that stuff fit over the stock PHB brace.
__________________
I don't deal with many S60 cars as it's not the axle you want for handling, which this part is very much about. I know it fits with standard type (non-fabbed) 9" rears and 12-bolts if they don't have a massive cover on them. I really cannot say with 100% certainty that it will fit with an S60 without any doubt. I think it would, particularly if you had adjustable control arms you could use to bump the axle forward a touch if you need too, and WITHOUT a massive diff cover.
__________________
