Setting rebound on Koni SA...
Old 06-01-2004, 02:58 PM
Edrummr's Avatar
Default Setting rebound on Koni SA...
Can anyone recommend a rebound setting for a front Koni SA in a 2001 Camaro? Pertinent context info: Front 1LE springs, stock rear springs. 35mm hollow front bar, stock/1LE rear bar.
I won't be track tuning this suspension so help me get in the ballpark.
Thanks in advance.
Old 06-02-2004, 02:59 AM
LittleDonny's Avatar
Thanks in advance.
I can't give you exact numbers, but IMO, soft in the rear and firm in the front to minimize snap oversteer. For the street you want mild understeer anyway.
Old 06-02-2004, 10:23 AM
Edrummr's Avatar
Thanks Little. That reminds me, I forgot to say that the rear will have 3rd gen Bilstein HD's. I figure I should set the front rebound fairly soft since the Koni's are only damping 360# worth of spring and they can handle MUCH more. Can anyone with Koni SA experience get me close? If 1 is full soft and 8 is full damped what should I start with? 2-3 ish?
Old 06-02-2004, 01:09 PM
LS1TECH Sponsor
Sam Strano's Avatar
About 4 sweeps backed off of the full hard setting. MHO
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 06-02-2004, 01:33 PM
Edrummr's Avatar
Thanks Sam. 4 sweeps from full it will be.
Quick Reply: Setting rebound on Koni SA...
