who sells coilover threaded sleeve for the rear only?
car has a moser 12bolt and the rear sits much higher than the front.
Id like to lower it so it will sit flush with the front.
Front will have bmr 550 spring with bilstein shocks
plans for the rear is also bilstein shocks but a custom spring set up.
what im looking for is a threaded sleeve insert that would simply fit over.
The moser spring mount has 6cm diameter.
I figured a 2" drop would drop the rear enough to match the bmr spring drop.
but how do i select spring length? who sells spring to match the threaded sleeve?
im thinking 160#
so it will be
F = 550
R= 160
im thinking 160#
so it will be
F = 550
R= 160
