Installing S60 & Adj. Torque Arm. Just checking if Pinion Angle can be set this way.
So I have an odd question. I'll be installing an S60 rearend in a few weeks and will also be installing a UMI adjustable torque arm. I will have the front end on jack stands and the rear wheels resting on drive up ramps, and since I do not have a drive on lift to set the pinion angle;
Will I be able to accurately set the pinion angle if ONLY the rearend is under load and the front end is level, but being supported on jack stands?
In theory, it feels like I can but I wanted everyone's opinion, thanks!
okay, thanks for clarifying! This will be my first time setting pinion angle and using an angle finder. I know my pinion angle should be -2 but where exactly should I be placing my angle finder? Thanks for the responses UMI & BMR!
If you have a smartphone download "Tremec Tool Box" to assist your pinion angle set up. Otherwise we sell an inexpensive angle finder like what you would find at most hardware stores.
I'm sorry about that, I completely misread that post. You want to place it on the bearing caps for a more accurate reading. Pinion angle is commonly "over-thought" on the boards here. It's not uncommon for us to set a car up and be so excited to drive it that we set the pinion angle after the first test drive. Also, every car reacts differently. No one set pinion angle will be perfect for every F-body. The 1-2 degrees is a good frame to aim towards.
