Supporting Suspension mods for my future build?
So I have a stock 01 SS 56k original miles car drives tight.
I am going to do the H/C package from texas-speed soon. Now obviously that will bump up the WHP significantly. I am trying to do this in pieces. Will the car be okay with all that extra power and stock suspension for the time being?
and when I do get to the suspension portion what is recommended?
Going for around 450WHP street car but go to track every week with it.
thanks-
thanks-
when you "build" a car, you need to start from the ground up, suspension, wheels and tires first, the stock shocks suck, then consider a rear end upgrade depending on final HP goals, then work your way forward to the trans then do the motor LAST, if you put to much power by building the motor first then you might break something down the road and these cars already need help keeping the tires from spinning.
So heres the real low down, you need to decide what is more important to you, getting the best 60ft times at the dragstrip, or having the car feel the best on the street, you have to sacrifice a little some where unfortunately.
Listen to the guys that actually have tried different setups, not just the sponsors trying to sell you the parts, as most of them will try and sell you everything under the sun and tell you their parts are great for drag racing, road courses and curing cancer at the same time while they can actually only do one thing well, and everything else poorly.
So here it is. If you want the best 60ft times at the drag strip, but are willing to sacrifice ride quality, handling and feel (and you WILL be sacrificing these aspects majorly compared to running a sport shock) then look into drag shocks like viking, QA1, strange, afco, comp engineering etc etc. Some of these shocks/coilovers are labeled as "can do all well" but thats stretching the truth quite a bit. Before Vikings came along the QA1s used to be the flavor of the month drag coilover that claimed to be good at handling too (and sponsors would sell these claiming they were great at handling), I (and many others) found out first hand how untrue that was... It, like the other shocks named above, is a non-gas charged (see shock fade) drag shock that has poor adjustment features and the company spent more time on marketing than actually building a good shock. Sorry, end rant...
On the other side of the spectrum there are sport shocks like Bilsteins, Koni, KWs, Ridetech, Penskie, etc.
These shocks are gas charged, and are aimed at handling and ride quality, have adjustments that actually effect piston speed (see precision) but will not launch as well as a drag shock. Think BMW like ride and handling, super tight feel, amazing neutral handling, yet great firm ride quality that is not jarring like the stock stuff you have now. You might sacrifice 0.1 seconds at the dragstrip but if you actually drive your car on the street you will love these.
If you want to talk to a guy that has been racing these cars for years (multiple national champion SCCA auto-x in an LS1 Camaro) about how shocks actually work and what are truly worth the money call Sam Strano at stranoparts.com. One of the few sponsors that won't BS you and will only sell you parts you actually need/are useful for your setup.
I went the route of doing a H/C setup before i did anything else to the car..everything else was 100% stock. It was pretty fun I must say but it handled horribly and was not going anywhere fast. Shortly after I ended up getting pretty every suspension piece I could buy except A arms/K member. Pretty much ended up putting each piece on individually and then drove around. It's a world of difference with all of the suspension pieces on the car and I couldn't be any happier with the end result.
