Need Rear Brake Help on a 95Z28
Old 01-26-2017, 07:29 PM
Cammed95Z28's Avatar
Default Need Rear Brake Help on a 95Z28
Okay so I knew I would run into some issues with the rear brake pads and rotor replacement, because I tried to research the rear parking cable and couldn't really find much... Sure enough, I'm having trouble depressing the piston back in, and I'm wondering if it's just because maybe I should have unhooked the parking brake cable shown in the picture below? I don't want to jump to conclusions here and say it's a bad caliper until I have to... Thoughts?
Old 01-26-2017, 07:44 PM
Spartan7's Avatar
You should not need to remove the parking brake cable to depress the piston, but it does need to be fully released.
Old 01-27-2017, 07:53 AM
Thanks for the quick advise! It turns out I was using the little brake caliper tool with the ****, and I needed a little bit more leverage with a large C clamp. After that, I was able to finally get the correct bolts off and swivel the caliber so that I could slide off the caliper bracket. Those rear brakes were harder than I thought, but I got the job done!
Quick Reply: Need Rear Brake Help on a 95Z28
