wich setting u use on lca relo's
Originally Posted by Assassin
did you use the upper hole or lower hole for remounting the lca?, thanks
Try each one out and get a feel for which feels better. We always recommend the 2nd the hole (middle hole) for non-lowered vehicles. This is not to extreme and gives you a good traction bite. Most cars running a lowering kit such as DMS, Pro Kit etc we always use the lowest hole. This seems to level the control arm out nicely or give just a slight angle downwards towards the rear. Hope that helps.
Ryan
