Adjustable shocks worth the extra money?
I need to replace my shocks soon and I have been looking at different brands. It seems that the adjustable shocks always cost more, but is the feature worth the extra money? Or am I better off just saving my money and going with some Bilstein Shocks?
hmmm, well IMO and i'm not suspension guru, it depends on what your needs/goals are. plus are you going to change out your springs also ?
Bilstein HDs I've heard are real good but only for stock springs. you go aftermarket springs and you SHOULD have them revalved, you don't have to but they weren't meant for heavier springs. going with adjustables you don't have to be so picky, you can use them with whatever spring you want to I believe.
also you can just go adjustable up front and get non adjustable in the rear.
hope that helps and if i'm wrong in any way, feel free to correct me =)
It depends on what kind of adjustability you are talking about. Are you talking about something as adjustable as QA1 shocks? That you can just adjust with a **** on the back of the shocks so you don't have to remove the shocks to make the adjustments? Or are you looking for something like an adjustable Tokiko (sp?) that you have to remove to do the adjustments too? I think a good set of 4 tokiko's are around $300 or so. A full set of QA1's will run you about $600 without the QA1 front springs.
Yes, adjustability is worth the money although you can't go far wrong with Bilsteins either. Koni shocks are the cat's pajamas and well worth the cost - ask anybody! Well worth it if you even think you may road course. Lots of people on this board run with Koni SA in the front and Bilsteins in the rear, so take that for what it's worth. QA1's are more of a drag shock.
