Need some input on the aerospace brakes
I had some real time consuming problems but was able to fix everything and make it work. Quality is good. Instructions are bad. Customer service is good. I do have mine installed and working fine now. You will save about 30-31 pounds.
You don't have to buy their expensive hose kit to make it work either. I bought two $5 high pressure stainless steel fittings to connect my lines.
Originally Posted by c5ls1vette
Do you remember what size those fittings are? That is alot of weight savings off of the front end.
thanks, Brandon
thanks, Brandon
If you need pics then send me your email address.
So that fitting is actually an adapter that adapts our metric brake lines to the areospace brake itself?
thanks for all of the info.
Be sure to deburr the line, clean it and insert the tubing all the way into the fitting. Torque to recommended specs. Be sure to make your cut on the line where it is round. It needs to be round to fit the tube fitting properly.
