help with brake install
do i need to upgrade my brake lines?? to STAINLESS STEEL or something better then stock?? im about to intall new rotors and pads and i was just wondering if this is necessary or not...if so where can i get one for cheap??
i found one and itz like 140 for rear and front... is it worth it??
my whole set up needs to break in first before I can truely comment on them, but supposed to give you better brake pedal feel. Try stranoparts or one of the other supporting vendors. Do a search in group purchase vendor sale areas as there were a few who were selling for 115.
The Earl's lines I got came with 5 lines. One for each brake and there is a 5th soft line at the rear of the car at the axle that goes to a tee if I remember correctly. I don't see the point if you don't replace ALL the soft lines.
The install is pretty straightforward. Bleeding the brakes sucks but other than being messy is pretty simple as well. Piece of advice, don't waste your money on speed bleeders. Ugh...bad experience.
Start here:
http://www.carbotecheng.com/faq-other-q3.htm
That is from Carbotech Engineering's website. They make some of the best race pads (and some excellent street pads as well) that you can buy. It is their thought on braided lines (and to some extent, mine as well).
Originally Posted by trackbird
Start here:
