SLP Camaro SS spring question
Old 03-04-2005, 04:02 PM
2KSS's Avatar
Thumbs up SLP Camaro SS spring question
Okay all you SS guru's out there !!
I have a 2001 SS and I would like to lower the car but don't want the 1 1/2" to 2" drop that the aftermarkets provide.
I have found some SLP springs with the markings:
SLP 3831 RRA
SLPF 300/450
SLP 25/93
SLP 41/95
SLP 30/95
Any idea if these are the 1LE springs with lowers the car about 1" from stock ht. ??
Let have your opinions and knowledge !!
Old 03-04-2005, 06:11 PM
TXAgZ28's Avatar
1LE springs don't lower the car. They're stock height springs with a stiffer rate (~290# stock, 360# 1LE).
On SS's (and maybe WS6's?), you could order a Bilstein/Eibach combination from SLP. I think there were two stages (grey or red springs?). I'm not the SLP option expert, I'm sure someone else will chime in and help with your part numbers.
Also might try searching for "SLP Eibach" or "SLP Spring Part Numbers"
Old 03-06-2005, 12:33 PM
01ArcticSS's Avatar
When I called SLP in Jan they said they don't make/have the 1LE springs anymore. But since they don't lower the car anyway, I'd go with aftermarket.
Old 03-06-2005, 10:08 PM
02SS0384's Avatar
You could look at BMR or Hotchkis which advertise a 1" drop.
Old 03-08-2005, 08:09 AM
2KSS's Avatar
thanks guys !
Quick Reply: SLP Camaro SS spring question
