Want to Lower my Ws6...HELP!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Guys-
I am installing Privats 18X9's on my WS6. I want to lower the car..Which kit should I go with? I am assuming that I will also need a APHR too?
I have heard good and bad things about each spring and shock kit out there, which have you had good luck with?
Thanks!
Thanks!
Originally Posted by VoodooWS6
Guys-
Thanks!
Thanks!
Do not overlook shocks!! They are the most important part!! Bilstein HDs are a BARE minium and far from optimum. You should look towards revalved Bilsteins or Koni SA.
Sometime APHRs are needed, sometimes not.
ZaneO is correct, shocks are the key to performance and ride
Here is an interesting point to consider (read the "Important Note" at the top): http://www.bilstein.com/pdf/PassengerCars.pdf
