Is it safe to use Mobil 1 synthetic greae on caliper sliding pins ????
Is it safe to use Mobil 1 synthetic grease on caliper sliding pins ????
I need to lube the caliper push pins and all i have right now its Mobil 1 synthetic grease. Would that be good ??
Its a pad guided caliper (that the abutement slides on 'pinch-bolts')... if it doesnt work freely, it can have a few associated symptoms. Most common is uneven pad wear or taper, vibration and noise.
