Looking into a K-Member install!
Before i go and buy a UMI K-member i would like to know whats involved in the install, and how difficult it is. I would like to lose some weight in the front end, and along with the new K-member i will be putting in new upper, and lower arms along with QA1 shocks.
So whats involved in the K-member install, whats the time, and difficulty?
Thank You
Thank You
Its about 10 minutes short of pulling the engine. Its how you pull the engine on these cars, except you keep the motor jacked up and lower the k-frame by itself.
I've done it. It was fun
It's not that bad after you've done it a couple of times. It is very time consuming though the first time around. You'll have to unbolt quite a few things from the K-member (shocks, sway bar, steering linkage, motor mounts, etc.) and to get to the motor mounts you'll have to drop the starter, alternator, and compressor.
