need advice on a rear spring...have prokit now
I have the prokit all the way around and over all its not bad. But Id like the rear to sit a litttle higher, 3/4" would be nice. The car sits pretty good and even but if I have a full tank the rear sits a tad lower and I hate that. I want a better rake. I also have big 315's on 17x11 rims that I get a little fender rub on when I have a passenger. If the rear sat a little higher Id be fine. Id also like the spring to be a little stiffer too, my car sees track duty so I think having a stiffer spring not allowing the car to sqat as much would help. Anyone have some advice on what would be a good spring for what Im looking for. Ive been told a few here and there but I want to know why you like it and would you recomend it. Thanks guys!
Try the stock rear springs with the hose mod. If you still have them it would be cheap and easy. The spring rate would work well with the 400# fronts of the prokit.
An adjustable rod-end panhard bar would help with rubbing when adjusted well.
