BMR strut tower brace? (warning LS1 IROC-Z swap)
Old 07-23-2007, 05:55 PM
01T/A88IROC-Z's Avatar
Default BMR strut tower brace? (warning LS1 IROC-Z swap)
Is BMR the only company that makes a strut tower brace for a third gen? Spohn, and UMI don't make one. I can't seem to find any other companies and I don't like the way the middle of the STB made by BMR looks weak because of the flattened emblem in the middle. Any suggestions? I want to put an LS1 in my IROC and I want the body to be very solid. Any suggestions?
Old 07-23-2007, 07:10 PM
Come on...no one?
Old 07-23-2007, 09:08 PM
02TransAm/Batmobile's Avatar
Patience is a virtue. Someone who is knowledgable on 3rd Generations should chime in.
Old 07-23-2007, 09:16 PM
Sorry
Old 07-24-2007, 11:04 AM
vjo90rs8's Avatar
why not check out a Third Gen specific message board like thirdgen.org
Edelbrock makes a 3 point STB for thirdgens, I had one on mine and it is a nice piece.
Old 07-24-2007, 02:37 PM
Moderator
jimmyblue's Avatar
I don't know from third-gens but on the 4th the brace has to
be considered more of a snubber for cowl shake, than a real
structural piece. Just about anything will do, so buy the color
you like.
Old 07-24-2007, 03:34 PM
RamAirTA's Avatar
I built my own 3 point brace many years ago. Can get pics if needed. Edelbrock makes a very nice 3 pt. and Hotchkis has a 2 pt. I would go with the Edelbrock as it triangulates the front towers with the cowl.
Old 07-24-2007, 03:47 PM
1QuikZ's Avatar
this company handles third gen parts. check this link:
www(dot)hawksthirdgenparts(dot)com/index.asp?PageAction=VIEWCATS&Category=389
also, they have everything else you need for an ls1 swap:
www(dot)hawksthirdgenparts(dot)com/index.asp?PageAction=VIEWCATS&Category=691
Old 07-24-2007, 05:56 PM
Eroc's Avatar
Basically any Strut Tower Brace will do. I suggest Hotchkis also Edelbrock (sp) sells very nice ones.
I like Hotchkis
Find both here...
www(dot)sfxperformance(dot)com/catalog/style/Suspension/Strut~Tower~Braces/GM/page_1.htm
Old 07-24-2007, 09:33 PM
Thanks you guys, I think I'll go with the chrome hotchkis STB. It will look good in a black car over an LS1. I appreciate all your help.
Old 07-24-2007, 10:34 PM
87formy's Avatar
Yeah, I'm pretty sure there's still a bunch out there if you look, but I'd recommend the hotchkis too because it looks way better than anything else out there. Make sure you get a steering brace too if you don't already have one.
Old 07-25-2007, 10:42 AM
Steering brace? What do you mean?
Old 07-25-2007, 11:31 AM
GR33N GoblinM6's Avatar
Hotchkis makes one.. Jamex used to make one.. Edelbrock makes one.. BMR...
the steering brace, is also called a "Wonder Bar".. it came on 86-89 IROC's as stock.. its a also called a steering brace.. its sits under the sway bar and attached from the steering box to the other side of the frame.
you need to go to www.thirdgen.org and search for "wonder bar" and "strut tower brace"
Old 07-25-2007, 04:13 PM
oh...mine already has a stock wonder bar. Thanks though.
Quick Reply: BMR strut tower brace? (warning LS1 IROC-Z swap)
