bilstein coil over question
I was wondering if any of you all have see the Bilstein coil over shock kit for our cars. I bought this 96 with a set on it and the shocks are gone, I am looking for the replacement shock for the kit. I can't seems to find anyone that sells the shocks for this kit..... I have found just the regular bilsteins but not that have the lock ring for the spring adjustment ring.Any help??????
__________________
__________________
Originally Posted by ssean92
looking and still dont see the coilover kit..... just the shocks
Originally Posted by Shockwave179
I think they sell a lot more stuff than what's listed on their site. You probably have to call to find out though.
http://www.lgmotorsports.com/catalog...oducts_id=1558
Sean; are the shock bodies alloy, and a dark grey/charcoal color, threaded for most of the shock body, with a Schrader valve tapped into the bottom?? If not, then they are NOT the LG Motorsports kit/setup, but some other kit that Bilstein maybe offered.
I have a complete set of the LGM Bilstein/Hyperco coilovers, for all four corners, with 2 sets of spare rear springs, ALL of the adapters/conversion pieces, and the adjustment tool. But I want a lot of $$$$ for this setup.
I have a bilstein set up, just need the rear replacement shocks for the rear. I have not seen this setup that I have anywere. and ofcourse I cant read the part # on the tag, just the #'s on the shock itself. I have no Idea were the kit was bought it was on the car when I got it, and it was on the car when the kid I bought it off of bought it.... I wonder if it was a old kit that has been discontinued?
I kind of doubt a "kid' would have invested $2300.00 into a handling only shock/spring setup, but I could be wrong.
Originally Posted by dailydriver
Ok, one more question will determine what you have. Where the shocks bolt to the suspension points, are there metal "spherical" bearings, or just the standard rubber bushings (on the tops and bottoms of the shock bodies)???
They are rubber, and the kid didn't, the guy that He bought it off of did all the mods to the car, all the kid did was drive it, and not do the maint. that it needed while he owned it
still no luck anyone have any Idea's. I ended up buying the HD ones for a temp, and put factory rear springs in it. But still wanting to find the replacement shocks
Can you post some pictures of them?
Here are my coilover conversions from Ground Control. Do they look anything like this with a sleeve over the shock?
http://img.photobucket.com/albums/v3...GCkit7copy.jpg
