lca's adjustable vs. non
what is the benifit for having adjustable lca's over non? how would you go about adjusting them and why? my plan is drag racing would adjustable benifit me over non? those of you that have adjustables did you adjust them at all and did you see a difference?
Copy & Paste Moderator
Your answer is in the "General Suspension Issues/Questions FAQ" sticky:
https://ls1tech.com/forums/suspension-brakes/696182-general-suspension-issues-questions-faq.html
That sticky is at the top of this section.
Here is a link to this exact topic:
https://ls1tech.com/forums/showpost....12&postcount=6
If you plan to do any kind of racing adjustable are better, you can set the tire exactly where it fits best, and once you raise or lower your car any the wheel is going to move in the wheel well.
I have c-moly with double adjustable rod ends and adjusting them is easy on the car and I also got the offset ones to allow room for a larger tire which you'll have to get if you plan to mini tub ever.
