What set up should I go with?
Old 01-23-2008, 09:17 PM
95fbird's Avatar
Default What set up should I go with?
Mods are in sig...this is a 10 bolt stock rear...will be changed when blown to a 12 bolt. My sixtys are consistent 1.62-1.68 range...loooking to lower.
So far I plan to buy
subframes
rear control arms
roll bar
torque arm
qa1 front adjustables
what Else do I need....not sure what to do about springs...I think some say leave rears stock. Also I removed front sway bar.
Car needs to still be streetable. thanks for your advise....im more of a power guy, not a chasis guy.
Old 01-23-2008, 10:57 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
you've got the power to easily get the 60's lower. i have a package that is a proven working combo and is less cost than anywhere. along with your list you will need lca relocators. the QA1's are fine, just overpriced. rear shocks are a good idea, also. your stock rear springs will be fine.
pm me for details and a quote.
Old 01-24-2008, 11:20 AM
LS1TECH Sponsor
Steve Burger's Avatar
Looks like a good list. Can you define streetable? Rod end suspension parts are by far the best. They will make a bit more noise. Does this fit into streetable for you?
Let me know if we can help. We have 5% off LCA, PHB, TA, and SFC through the end of January. We stock QA1 shocks and springs as well.
Old 01-24-2008, 06:25 PM
95fbird's Avatar
any 1 else out there with proven street/strip set ups..btw im making 400 rwh with like 383 torque or sumthing like that
