BMR Relocation Bracket...
Old 08-17-2012, 12:31 AM
ryany's Avatar
Default BMR Relocation Bracket...
Ok i bought a relocation bracket back a couple of months ago. I installed it tonight my question is it mainly stays at the track where is a good start point? I have read on some of the forums the lower the more aggressive. And some says higher i go it will be more aggressive. Please help Thanks
Old 08-17-2012, 02:49 AM
02TransAm/Batmobile's Avatar
I agree. The panhard relocation bracket should be sold as a kit - a bracket for the passenger's side and a bracket for the driver's side to completely level out the panhard bar.
Old 08-17-2012, 08:11 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I am pretty sure you are talking about the torque arm relocation bracket. With the torque arm relocation bracket the higher you mount the torque arm the harder it will hit the tire but it won't carry the power out as far. The lower you mount the torque arm the softer it will hit the tires but it will carry the power out further.
Each car is a little different so play around with the settings and see what your car really likes.
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 08-17-2012, 08:25 AM
ryany's Avatar
Ye its a torque arm relocation sorry about that which hole would you consider a good starting point.
Old 08-17-2012, 08:58 AM
BMR Sales2's Avatar
How much power does the car make? What tire are you going to be running? What kind of transmission? If it is an auto what size stall? Give me some details on the car and I can definitely help you out better.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 08-17-2012, 09:14 AM
ryany's Avatar
Its a Head and Cam car Im running 275/60/15 Hoosier Drag Radials it has a 4l60e Transmission with SS 4000 Torque converter. I have been 11.1 with 1.47 60ft on side of the Trans.. Maybe this will help Thanks
Old 08-17-2012, 09:19 AM
BMR Sales2's Avatar
It sounds like the car is hooking pretty well on the previous setup so I would try it up a little higher to see if you can drop that 60ft time a little. I would run the bottom bolts in the 5th hole up from the bottom. Setting it up this way will hit the tire harder then you were before so it may be too much and you may have to back it down a little but I think that will be a good starting point.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 08-17-2012, 11:33 AM
ryany's Avatar
Ok thanks for all your help.
Old 08-17-2012, 01:54 PM
BMR Sales2's Avatar
Not a problem. Once you get everything set up and make it to the track let us know how the car does.
Kyle
__________________
Glenn ***
Sales Tech
813.986.9302
Old 08-17-2012, 05:18 PM
ryany's Avatar
I will thanks kyle i have one more question the torque arm is real close to the tranny is this right?
Old 08-17-2012, 06:33 PM
Am I going crazy? I thought when I replied to this thread, you were initially talking about the panhard bar?
Old 08-18-2012, 02:00 PM
ryany's Avatar
And i have one more question my fuel lines is almost touching the side of the bracket. How can i adjust with them like that?
Old 08-18-2012, 07:20 PM
garygnu's Avatar
fuel lines can bend a little .get a degree gauge to check your rear angle.
Old 08-20-2012, 08:48 AM
BMR Sales2's Avatar
Yeah this is normal. The torque arm should sit right next to the transmission and as long as it isn't making contact with the transmission it is fine.
When you have everything mounted up it gets real tight in that area so as long as the line are not touching you won't have any issue. If you want post up a picture of what you are working with it may help me to help you out.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 09-05-2012, 10:29 PM
ryany's Avatar
Ok I have a few pics of this on the car I had recently been talking to BMR to help solve the problem. My question has anybody else experienced this? Just seeing if im the only one? Thanks ryany
Attached Thumbnails BMR Relocation Bracket...-2012-09-05-17.13.18.jpg   BMR Relocation Bracket...-2012-09-05-17.16.04.jpg   BMR Relocation Bracket...-2012-09-05-17.15.04.jpg   BMR Relocation Bracket...-2012-09-05-17.17.05.jpg
Old 09-06-2012, 12:05 PM
ryany's Avatar
Bump pictures...
Quick Reply: BMR Relocation Bracket...
