Small problem please read brake guru's
Ok so I did a ls1 style brake conversion this weekend using an ls1 set of spindles, calipers, pads and rotors. During the swap I had to change my ball joints, no problem there. The problem is, I never got the mounting bolts for the caliper bracket to mount to the spindle. It's just 2 bolts for each side. I went to my local Ace Hardware and just picked up 2 bolts that fit the thread and were long enough. I tightened them down, but they keep seem to be loosening up.
My question is, where the hell do I get these bolts and why are the bolts I have installed slipping? When they are tightened down, the brackets don't budge, but after braking for a while they loosen up.
Any help would be great.
Those things have a habbit of doing that. I've read several posts of guys having that problem. Are you using zinc coated bolts (shiny)? If you are that might be your problem. That coating acts almost as a lubricant. I put ls1 brakes on my third gen and A LOT of people had that problem when using everyday hardware. Just make sure you use a good flange head bolt or an oem one.
I would just loctite those bolts, but soon, a friend of mine just lost a caliper because they worked their way loose, either that or a lock washer on it, that should solve your problem much easier then trying to find GM stuff
