ABS Removal Pictures
Brakes are finished... I removed the ABS, got a double flare tool and refinished the lines in standard sizes. I cut a plate and mounted the line lock and proportioning valve on the master, as you can see:
Split the fronts by the K-member:
Now my question is, does the standard bleed method work when you've emptied out the system? Any tips?
Thanks!
Thanks!
