UMI on-car adjustable PHB keeps coming loose
Old 07-07-2008, 05:48 PM
turbowhistle86's Avatar
Default UMI on-car adjustable PHB keeps coming loose
I installed a UMI on-car adjustable PHB about 2 months ago, and every 2-3 weeks the adjustable portion keeps loosening and creating a clunk around corners and over decent bumps. Is this common and should I not put loc-tite on it? Crawling under the car every 2 weeks to fix this is getting real old, really quick.
Old 07-07-2008, 06:35 PM
LS1TECH Sponsor
Sam Strano's Avatar
The jam nuts have to be TIGHT. Don't be shy.... And there is no reason you can't use Loctite. In fact I'd recommend it, but it's not a substitute for not getting the jamnuts tight enough in the first place.
I know many don't have the correct wrenches and use something close, or channel-lock type pliers, what have you to tighten things up. That's not good enough. Maybe you have the right tools, I don't know, just saying that I've run across that more than once.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 07-07-2008, 08:16 PM
lastcall190's Avatar
Mine used to do the same, used loctite, but I will admit, I used an open ended wrench. What would the right tool be, Sam?
-J
Old 07-07-2008, 08:22 PM
yeah, I guess I will have to get some loctite and wrench the be-jesus out of it...I've definitely got the right tools (some I probably don't know the name of)
Thanks guys!
Old 07-07-2008, 08:23 PM
Wanna post a pic? I'm having visions of a HUGE brake line wrench...
Old 07-08-2008, 08:41 AM
haha, I would post one for ya, but my tools are at my new house, about 60 miles away.
Old 07-08-2008, 08:48 AM
Funkster's Avatar
I used two big open ended wrenches. Cranked on it with the car on the lift. Mine has been fine so far. Had it about 2 months.
Old 07-08-2008, 10:54 AM
LS1TECH Sponsor
Sam Strano's Avatar
Right tool being wrenches that actually fit the nuts. Nothing special in terms of tools, just ones that fit and offer plenty of leverage.
__________________
Old 07-08-2008, 11:23 AM
Gotcha, I'll just measure and go buy some open ended wrenches. Thanks.
-J
Quick Reply: UMI on-car adjustable PHB keeps coming loose
