The dumbest Koni question ever!
So , I decided to play with the settings on my Koni's for the first time and I have retard question. If left is softer and right is firmer....are both Koni's set the same way? Or is it based on looking directly at it?
I.E. I moved the adjustment all the way towards the back of the car on both sides, then forward 5 towards the front of the car. Are they set both the same? Or, is one of them firmer/softer than the other?
When facing the shock to make adjustments you adjust them in accordance with "your" physical left, and right. For Example: You adjust the left front shock 2 full sweeps from(your) left to (your)right, then when you adjust the right front shock you also adjust it 2 full sweeps from (your)left to (your)right.
Got it?
Got it?
