Alignment Question
Old Aug 10, 2008 | 05:16 PM
317BORN's Avatar
Default Alignment Question
How do you adjust the alignment on the front suspension of a 02 trans am?
Old Aug 10, 2008 | 06:29 PM
leadfoot4's Avatar
The lower control arm is retained by two large bolts. One is mounted at the front of the control arm and runs horizontally. That sets the camber. The other bolt, at the rear of the arm runs verticlly. It has a slight effect on camber, but is the primary caster adjustment.
