Has Anyone Converted to a Short Front Spindle?
Old 04-14-2011, 12:30 AM
  #141
JasonWW's Avatar
So I was looking at this bag placement and it occurs to me that if I sacrifice a little stroke, I can angle the plates a little differently so as to minimize the angle that the bag see's.
Old 04-15-2011, 04:40 PM
  #142
JasonWW's Avatar
All new measurements.
Ideally, I'd like to raise the K-member 1.5" so that it's level with the side skirts. I need to grind a bump off the bell housing and then see how high I can get the motor/trans.
Old 04-15-2011, 11:10 PM
  #143
JasonWW's Avatar
When you measure the wheel mounting flange to kingpin axis, the F-body spindle and hub is 4.5" and the Solstice hub is 3.5". So just swapping spindles and hubs means that the front tires would be tucked in 1" more.
The solution? Have 1" hub adapters made that will change the bolt pattern and give me the correct center bore (70mm) for my existing wheels.
Photos so I don't forget.
Old 04-17-2011, 10:13 PM
  #144
JasonWW's Avatar
I'm going make me some new lower control arms. I don't know a lot about them, but here is my idea based on 2x3 and 2x4 1/4" wall rectangular tubing and using 3/4"-16 bungs for either rod-ends or Roto Joints/Del Sphere bushings.
Tweaked a little to make it look nicer.
Old 04-18-2011, 05:28 AM
  #145
JasonWW's Avatar
I'm thinking I'll go with this upper control arm. Length has yet to be determined.
It uses the Moog K772 threaded style upper ball joint that is very common in race circles. I need to get some specifics on this joint to make sure it will fit the spindle. It has 7* taper. I'll probably just take the spindle down to the auto parts store and see if it fits.
On the lower ball joint I need to use the Moog K6537. This is the Solstice and C5/C6 vette ball joint. I believe it has a 7* taper. I can't find any locally, all special order. It would be nice if I could find a screw in ball joint, but due to the spindle being aluminum, the tapered part is 1/2" longer than steel spindles which makes them hard to find. Roughly speaking, the big end of the taper is 0.8125 and the little end is 0.5625. Tapered length is 1.5".
Old 04-18-2011, 11:46 PM
  #146
JasonWW's Avatar
I have 3 basic bushing material choices: Rod-end, rubber and delrin. Polyurethane is doable, but it's not to my liking.
They can all be used with a 3/4"-16 weld-in bung. $6-$13
Rubber $28
Spohn Delrin $37
Rod-ends $15-$35
Old 04-19-2011, 06:58 AM
  #147
JasonWW's Avatar
Based on my rim/tire and the Solstice spindle, I know my lower ball joint is going to be right at 6" above the ground. In order to keep my LCA as flat as possible at ride height, I can either use the stock K-member mount holes or lower them slightly. Here are the arm angles based on me raising the K-member/engine 1" and the ride height set at the skirts at 4.5" (4" at K-member).
Note that there is less than 20* of movement for the entire 9" of travel. That means I can use a roto joint in the stock caster bushing location as it has 28* of movement.
Old 04-19-2011, 09:49 PM
  #148
JasonWW's Avatar
Fricken ball joints are kicking me in the nuts.
The lower one is the same as a C5 and C6 vette and runs $100. $25 bucks for a cheapie which I'm not feeling too good about. I don't want the thing breaking on me.
The upper appears to be built into the Solstice control arm and is not removable. Yep, looks like a new upper arm is only $64. Doesn't help me, though.
Locally I found a screw-in Moog K772 upper ball joint which is what that race adjustable control arm uses and it's too large to fit in the spindle. So I can enlarge the spindle hole at least 1/8", but it's going to weaken the spindle.
So I'm kind screwed.
This is a budget build, so I may go to my local salvage yard and pick up a complete lower A-arm with used ball joint for $65. I can either try and use the complete arm or just pull the ball joint out to use in a custom lower arm.
I don't know what to do about the upper joint yet.
Old 04-20-2011, 11:52 AM
  #149
JasonWW's Avatar
I got lucky. SPC offers 4 different upper ball joint plates. Of those, the "Midsize GM Metric Bolt In" ball joint, Moog K5208, fits this spindle. The K5208 is easy to find and runs about $25, so that's great.
Old 04-25-2011, 08:21 AM
  #150
JasonWW's Avatar
What do you guys think about hubcentric wheel adapters?
I'm having second thoughts about them due to their price and extra weight.
I'm seriously considering swapping over to C5 hubs. I know the rears can be used in the front, you just have that big splined hole doing nothing.
Now I'm thinking, I know that the F-body front hubs have 47 teeth on the ABS rings and my car is 4 channel and the rear rings on the axles are also 47 teeth. I have no idea about the Solstice hubs. I was thinking of making my own rear independant suspension anyway, since it's much simplier in comparison to the front.
So why not run Solstice spindles at all 4 corners all converted to C5 hubs? Maybe even use rear hubs all around. My ABS and TCS would remain functional and those hubs are probably beefier than the Solstice ones. If they are designed to handle the 295 tire on the back of the vette then they should handle my setup no problem.
Make sense?
Old 04-25-2011, 08:34 AM
  #151
JasonWW's Avatar
A quick update. The Solstice spindles are the same except for the brake mounting lugs. Fronts are spaced wide, rears are spaced narrower.
I don't know how I missed that.
Also, it appears the 13" and 14" front Vette rotors are going to bolt right on. The hat height is within 2mm. So they will sit further in by 2mm, but I think it will clear everything. If need be, a thin spacer can be made.
Since the stock Solstice rotors are only 11.6" I think there will be room for a simple adapter plate to space the caliper out further. I'm wondering if I should buy the bigger rotors and CTS-V calipers now or save some money and slap some 13" rotors on with my stock calipers.
Old 04-26-2011, 04:01 PM
  #152
JasonWW's Avatar
I got the vette lower ball joints today and it looks like they are the same mounting diameter as the stock ones. That's great, it gives me the option of buying premade sleeves from Spohn.
CNC machined from 2.75" o.d. x .375" (3/8") wall seamless mechanical tubing
SKU# SYZ-BJC-1
$15.00 each
Old 05-05-2011, 10:54 PM
  #153
JasonWW's Avatar
The question on my mind right now is whether to go the easy way and run a 6" upper control arm like Randy:
Or if I should modify the frame and run a much longer 10" upper arm.
I can use position 2 or 3 or anywhere in between.
Old 05-06-2011, 12:01 AM
  #154
JasonWW's Avatar
With the stock frame rails, I can run a 6" arm like this:
If I replace the front frame rails with 2x4 tubing, I can run an 8" arm like this:
Or a 10" arm like this:
It just depends on how long I want the upper arm.
Old 05-06-2011, 01:04 AM
  #155
ChrisRZ28's Avatar
He's not running it anymore. Have you seen the pictures on Fraxx? It's a shame what happened to his car.
Old 05-06-2011, 01:13 AM
  #156
JasonWW's Avatar
No. I don't see any bad threads from him. What happened?
Ah, Found it. Some one else started a thread about his big crash.
http://www.frrax.com/rrforum/index.p...opic=14913&hl=
Old 05-06-2011, 02:20 AM
  #157
JasonWW's Avatar
Here's the lower arm with the shock and bag locations sorted out.
Old 05-10-2011, 05:26 PM
  #158
JasonWW's Avatar
I'm really having a rough time deciding on what tubing to use. Most all the aftermarket tubular arms are made from 1.25" 0.120 wall DOM. I want mine stronger so I was thinking 1.5" 0.188 wall DOM, but I can't find any locally. What I can find is 1.5" 0.120 wall DOM for $108 for a 20 foot length. The larger diameter is automatically going to make it stronger than the 1.25" stuff and that's important since the weight pushes down right in the middle of the arm.
Does anyone have any doubts about the 1.5" 0.120 wall DOM not being strong enough?
The ID would be 1.25" and there are 2 places selling 3/4"-16 RH bungs that fit it. McMaster Carr $6 and Ballistic Fabrication $12. I just ordered from MMC.
My balljoint cup is coming in from Spohn here in the next couple of days ($12 shipping!) as well as a rear C5 hub. I think I'm going to run rear C5 hubs on all 4 corners. C5 spindles in rear as well.
Old 05-10-2011, 08:45 PM
  #159
JasonWW's Avatar
I tweaked it to give the ball joint cup some more coverage.
I plan to use the Spohn Del-Sphere for the camber bushing.
I'm not sure about the caster bushing. Maybe the stock rubber style to improve ride quality?
Old 05-10-2011, 11:11 PM
  #160
JasonWW's Avatar
Dang, I just now noticed that the McMaster Carr bungs are 4130 Chromoly and they already shipped them. I'll have to return them and get the ones from Ballistic Fab since they are 1020 steel.
Quick Reply: Has Anyone Converted to a Short Front Spindle?
