MS4 cam good for stock motor??
Old 07-06-2009, 09:36 PM
zz28Junior's Avatar
Default MS4 cam good for stock motor??
Ok i have a 2000 z28 camaro and its auto...all i have is TSP 1 7/8 headers TSP Y pipe and a SLP exhaust and tuned.....and i wanted to know if my stock motor can take the MS4 cam like could i run it with out a problem??...or would i need to get heads?.....cause i just want a good strong cam for right now..any help would be great thanks
Old 07-06-2009, 09:47 PM
00pewtertransam's Avatar
well i had this cam in my car but i was a m6. i had this cam with stock 243's. so you should be just fine. just make sure you get a stall that will get along with this beast of a cam. in my stick car this thing would pull like a mother in third and fourth gear. i mean thats where i would start walking people. evcen people who had more done than i did.
Old 07-06-2009, 09:55 PM
Trev_SS's Avatar
I agree with 00pewtertransam my ms4 pulls like a freight train in third and fouth gear. It is like it builds up boost in the first and second gear and then BAM!!!!! That bitch is gone.
Old 07-06-2009, 10:11 PM
98mysticZ's Avatar
ran it in my 98 with no problems... till i spun a rod bearing... but just run it it will be fine.. and pulls like a beast
Old 07-06-2009, 10:32 PM
yeah it is crazy how it just takes off up top. i now have a different motor so now have a bigger cam but. i do miss that cam. it turned so many heads when i started it up and you heard that chop.
Old 07-06-2009, 10:59 PM
ls1_sw's Avatar
oh really??? maybe i need to upgrade from the ms3 to ms4
Old 07-06-2009, 11:39 PM
whatsa347's Avatar
I run the same cam with an m6 also, its definitely loud as hell and is one hell of a cam. Be careful at low rpms it absolutely HATES it. I also run stock 241 heads with the spring kit from tsp and it does just fine i wouldnt worry about it.
Old 07-06-2009, 11:49 PM
this is why i said find the right stall!!!!!
Old 07-06-2009, 11:59 PM
Pwebbz28's Avatar
I think you could get away with a smaller cam and make the same numbers + be more driveable.
I would look into something along the lines of 230's duration and around 600 lift.
The f-14 and f-13 from Futral are wonderful cams.
Old 07-07-2009, 12:09 AM
TXws6's Avatar
you plan on daily driving?? Pwebbz28 nailed it, especially for an auto there are better choices!
Old 07-07-2009, 12:25 AM
i have a friend with a 02 camaro with the ms3 auto with a small 2500 stall 3:73's and went 11.95. runs low 12's everytime he touches the track. he has sprayed a 100 shot to a 11.1
Old 07-07-2009, 05:02 AM
stickymickey80's Avatar
Go with a TREX. but theyre right youll need a big stall for an automatic. try the ultra yank 4800 that will be perfect. Remember TREX is the best cam
Old 07-07-2009, 11:02 AM
Trev_SS's Avatar
Also I daily drive the car and it drives just fine. You have to have a good tuner. My tuner takes it out on the street and we tune until I fill like I have were I want it. I have 4.10 gears with my M6 and I can cruise at 65 in 6th gear with the rpms at 14-1500 rpms just fine with out any surging. Good luck with what ever you choose. The MS4 is a great off the shelve cam.
Old 07-07-2009, 11:54 AM
zz28Junior's Avatar
Yeah its my daily
Old 07-07-2009, 12:01 PM
zz28Junior's Avatar
I i get the MS4 cam im gonna get it with the TSP Camshaft, PRC Spring Kit & Pushrod Package from texas speed
Old 07-07-2009, 01:32 PM
i bought this same package when i bought this cam and it worked great. no probs with anything.
Old 07-07-2009, 02:38 PM
zz28Junior's Avatar
ok thanks everybody
Old 07-07-2009, 10:11 PM
98mysticZ's Avatar
yea i dailyed mine no problems... sick as **** sitting at the light the idle is CRAZY awsome lol
Old 07-08-2009, 12:45 AM
whatsa347's Avatar
True that
Old 07-08-2009, 10:16 AM
bambaboy's Avatar
did ya'll get tunes after the ms4 cam?
