Car Idles At 2000rpm's
so i replaced the TPS cause my ideal was at 11rpms and now my freaking car is idealing at 2000rpms someone help me i have this car sold if i can fix this problem. Could it be the hole in the trottle plate making it do that? Could it be the mass air flow sensor? someone help guys is waiting to buy but cant figure out the problem
Thanks Brian
Thanks Brian
brake cleaner is supposed to be non-flammable so you may want to use something like starting fluid or carb cleaner. Gumout carb cleaner is very potent and seems to do the trick for me.
My cars idle is at 1200. This happened after I changed the the TB. I hope this trick works. If so, I owe u a six pack!
Ok guys replaced the tps sensor and reset it like yall told me and it idled fine for about 2-3 min utes then went right back up to 1500-1700 rpms what do yall suggest to do now
hey guys thanks for everything got it fixed it was the IAC it was stuck open allowing it to idle real high it had alot of carbon build up and wasnt working properly changed it out back down to 750rpms thanks everyone
