How much can I expect to pay for FAST
Hey Ryan, might have seen you driving around town but who knows. I live in Murphy too. Shop around in the sponser section and you can find pretty good deals on them for what westtexasbuff quoted.
Is using a taller injector better than replacing the fuel rails? Im buying the 102 in anticipation for a decent H/C setup . Plus I just bought a new water pump so I could grind it down pretty easily while its off the car.
Charlay, I think I may have seen you before with a few other cars in the Lowe's parking lot?
LS1TECH Sponsor
Picked Up 13 RWHP on a heads and cam GTO from a Fast 92 to a Fast 102. Good luck Finding any used fast intake...By the time you Buy a 102 intake, TB, and fuel rails expect to spend 1500ish
No. With a 102 you HAVE to replace fuel rails regardless if you're installing it on a LS1/6. Either LS2 style OEM fuel rails (WS6 store sells a kit) or FAST fuel rails have to be used for a 102 intake. I think Nasty Performance (sponsor on here) also sells some billet rails that work with the 102 intakes.
I picked mine up for $650 through the forums. Had my car retuned and it picked up a good bit of power in the midrange 15-20hp/20+tq and held my power out another 750RPM over an LS3 manifold. The 102mm gained almost 40hp over the LS3 manifold at 6k+RPM where the LS3 manifold dropped off.
Totally worth it!
Totally worth it!
