WTH? two thermostats and still getting hot at idle. hELP PLEASE!
So I installed a hypertech 180 and that was not opening till 200*+ . But it didnt even open on my engine. I had to boil it to get it to open. So then today I installed a 160* in it. this time I put it in a pot and cranked up the stove to make sure it worked before installing it. It opened up right away so I went ahead and installed it. So I fill up the rad and start it up and let it idle. I wait and wait for the water to go down indicating that it opened. well, it never goes down so I look at the autometer gauge and its at 230*!!!!! WTF?!?!?!
what the hell is going on? why are they not opening when they are in the car? install is about as straight forward as it gets but could I really have done something wrong?engine is an 02 5.3 and radiator is from an LS car. I also have the heater bypassed with the U shaped hose.
Im still using the truck one but its hooked up to the lower port by the radiator cap.
I talked to a friend and he said its cause its not getting water to the pump side of the thermostat because of air being trapped in there.
After I shut off the engine I had put the radiator cap back on and it created vaccum which caused the hoses to collapse. when I took the rad cap off the engine sucked all the water from the radiator into the block. I added some more water to the rad and turned it on again. this time i could see a bit of flow through the radiator and then it started to overflow. He said the overflowing is due to the ait trying to get out. I think hes right. Once it stops overflowing then i can add a bit of water untill it reaches the right level and all the air has circulated out.
The way I bleed the system is remove the crossover tube on the passenger head and add water until water comes out of the crossover hole. When you start the car you should be able to see water flowing in the radiator from the hose going to thecross over
yup. it had some serious air in it. I tried and tried and nothing seemed to cure it. So I took the upper hose off and I shoved the water hose into the rad fill cap till it came out of the upper hose. Then right away I put it in the water pump inlet(non t-stat side) and waited and waited till it finally came out of the steam port. I then quickly installed the hose back on and started up the car before the water all drained out. Right away the water started to flow like it should and coming out of the steam port and flowing through the radiator. Temp stayed at 165* idling. Thanks for all the input guys....this was really pissin me off....
