finished my motor install
Well guys I built a lq9 6.0 with ls3 top end, 92mm throttle body, g5x2 cam, 42lb injectors ls2 timing chain, ls6 oil pump, ls7 lifters. I was on a budget and didn't have the heads ported or polish.
Installed it over the weekend drove it Sunday and had it tuned Monday. Today driving home from work the tach stopped working. Do you guys think its a ground wire maybe I forgot?
Thanks chad now that you said check the passenger side kick panel. I remember pulling a little hard on the wire harness going into the firewall from the outside by the computer.
My Ls2
I have a few bugs to work out. The tach stopped working but works on my snap on scanner. Plus I'm getting a p0343 cam sensor volts high. I thought I fixed the problem the other day but didn't.
