FAST 102 and FAST fuel rail = fuel leak. Need better rail bracket
So after all this there was yet another fuel leak, after 20 or so phone calls to FAST we got someone on the line that knew what they are talking about, there is apparently a known issue if using 60# injectors, they are a hair shorter than others and need a small shim in the injector bore, you place them in the intake and then mount the injectors again.
After doing this the injectors fit better than ever and do not leak, I even tried my hardest to cause a leak my pushing, pulling, yanking, cussing the injectors and still no leak.
If you are having leak issues with a 102mm intake, call fast and ask them about the injector shim kit they are supposed to supply with the intake to prevent the injectors from leaking.
The following users liked this post:
ssdungeon (11-09-2019)
