9 Second C6 Z06-All Motor at RPR **Video**
I am at the track weekly and every once in a while I see a car that impresses me. Well this car is a new level of overkill. C6 Z06 with factory ls7 short block. No nitrous/boost. Car has heads/cam/intake and RPM auto. With a 1.2 60 foot and a 9 second pass... WOW. Check it out:
Callaway CAI
Fast 102 with NW 102tb
WCCH stage 2 heads
BTR stage 3 cam
ARH headers
Stock Mufflers and CATS
No milling of heads (stock compression)
Pump gas motor, pretty much an average boilerplate build as far as the world of Z06 cars go.... would probably make around 560 rwhp with a manual, but is down at 530ish through an Auto.
Auto is 4l65E stage 3 from RPM Transmissions with Yank converter. Have upgraded half shafts and on Weld RTS wheels with a Hoosier 315-17 drag radial. Raceweight is 3340 lbs as per Texas Motorplex scales. Has an RSD rollcage in it.
If its not mentioned, its stock.
Thanks
The set-up is simply:
Callaway CAI
WCCH stage 2 heads
BTR stage 3 cam
ARH headers
Thanks
Callaway CAI
WCCH stage 2 heads
BTR stage 3 cam
ARH headers
Thanks
This was an A-typical dynojet.... converter was locked, albeit, its just a single disk, so probably shouldn't have been. Would be another 20-30 rwhp if I still had the manual in it.
Thanks.
He drove it from Dallas to Houston for work. And decided to stop off at the track and run some passes.
Turn the hate down a notch. this is a pretty bad little work car, on stock suspension and 17in wheels and drag radials.
I'll say it again, do you have a hard on for me? You love to quote me, but you and Insoector12 seem to have a close relationship. Jeff has always been friendly to me, gone out of his way on 2 car parts. But I have never seen you or him post timeslips. I can't imagine where I'd be if I didn't take 3 years off fishing every single weekend with my boats out of South Padre Island a long with a divorce.
Again, the car posted is sick. I've watched it and appreciate it. I personally wouldn't do it on that car.
If you have an issue with me personally, come to our private track rental on March 1st. I look forward to meeting you.
TT-TECH Veteran
Yep, I was there, called his ET before his 9.89(called a 9.90) to my friends and girl before the pass. Called a 9.85 the next time. You are so butt hurt over me it's unreal. The owner has a great setup for a 1/4 setup. There is nothing to take away from him. His car rolled out very hard, in person and ran a great ET. It's not my cup of tea since I like a Z06 to cruise, run around MSR and the street with no changes. Public forum, my preference.
On the car yeah its pretty dang fast for what it is. I can say with the comment about throwing a blower or turbo's on a car that doing that auto conversion isn't cheap either, so its all about where you want to spend your money. And what your going to do with the car.
Who are you?? I was just quoting someone who came across as a hater and said turn the hate down a notch???
The car is a cruiser on stock suspension.. He could do msr in it with different tires I would think??
Everyone else would need the same because you aren't running 9s without at least drag radials.
