Highest Stock GM head cam only Ls1 numbers?
Trying to figure out the highest Dyno numbers of a stock bottom ls1 with Stock GM Castings. My car make 448/398 on Serious HP Dyno here in Houston 2 nights ago. It's a Dyno jet. I'm thinking I might be pulling a record here. Here's the specs of the motor:
Stock bottom ls1
Stock 799 heads
Custom grid cam -
23x/24x .62x
Stock fast 90
92mm Nick Williams TB
LS3 Maf
MTI clear lid
1 7/8 headers
3" ypipe
Cutout
3.90 gears
3200 Circle D stall
Built 4l60e
Unlocked converter
Stock bottom ls1
Stock 799 heads
Custom grid cam -
23x/24x .62x
Stock fast 90
LS3 Maf
MTI clear lid
1 7/8 headers
3" ypipe
Cutout
3.90 gears
3200 Circle D stall
Built 4l60e
Unlocked converter
Theres no secret to making hp on a dyno, thats the easy part. Drivability is the hard part to tuning.
Please dont take my post wrong, I was not trying to knock your tune or that shop. I was just saying those numbers are not inline with with the hundreds of f bodys I have dyno'd even ones I didt tune. Are those numbers SAE,STD, UNCORRECTED?
I have the highest stock head, stock cam, lid/SSRA only, 2002 Z28, six speed, hardtop, owned by a guy named Nick dyno. These highest dyno/fastest quarter mile posts with intricate details are ridiculous.
Unported 243s are worth 15-20 rwhp. If you had stock LS1 heads your cam only dyno would have more merit but this isn't the case. I've seen one M6 car make 448/400 cam only with unported 243s and he didn't make a thread like this. Has this car seen a track? That will help your credibility significantly.
Not freaking out but there's so many people that try to have record dyno numbers based off their unique build. Your track time is definitely solid. You should include it in your OP then people won't give you so much flak. If you do ported heads with the FAST it's definitely got the potential to be a 10 second car.
