Possible bad tune
Thanks for all the input so far, guys.
Haha. No problem. You can always count on me and Daler Mehndi. LOL. I think that I'm a 10-year member by now, but I'll have to check. Thanks. I've always gotten good advice on here, so I'm sure that I'll get it figured out.
Tomorrow, I'm going to check the ECT sensor connector. What voltage should I expect? Also, I saw something online about a secret menu on the display to see the current ECT sensor reading - -40 if unplugged and 419 if there's a short or whatever.
The battery is secure. I checked the two grounds near the battery, and their static reading was 12.64 V. I forgot to do a dynamic test. I read the resistance on the ECT sensor connector and it was 4.27 kilo-Ohms.
#32
#35
Yes, I actually had that problem last year, but it caused problems with the doors not locking, cabin lights, etc. I checked the buffer that I put between the metal harness and wires and it's still in place. I didn't notice anything else.
#36
Yesterday morning on the way to work, the car died, and it threw the ECT code, so I dropped it off at a shop. Today, the guy said that they didn't find any problems in their diagnostic test. I mentioned that maybe it's a bad BCM, but he said that it would instead be an ECM problem. As for dying, he said that he noticed there was a bit of slack around where the MAF and throttle body are attached and that maybe the inflow of the extra air is causing it to die. I assume that he means in conjunction with whatever is first causing the car to act up.
#37
If that is the case it may be the crank sensor going bad Or your fuel pump
Just to be sure the car is full on coolant correct?
I have a bad ground on the back of the block and it causes my needles to jump around when I start the car and occasionally resets the trip odometer
#38
When it died did it still want to crank over but not start?
A bad fuel pump didn't even cross my mind. A pressure check should be a quick and definitive indicator if it's bad.
Well, I haven't actually popped the radiator open recently, but when I did change the ECT sensor, coolant did leak out from the block.
The shop guy was adamant that he would have seen a bad ground/reference in his diagnostic test.
#39
Yes, it seems like I have to hit the accelerator to get it to start, and yesterday it stuttered and lunged after it restarted. When it does die, it happens when I'm stopped and the RPMs are low. If I can give it some gas when it feels like it might die, it doesn't.
When my IAT was bad the car would misfire like hell at anything above idle because it read temp as -136 degrees.
When my coolant temp tensor broke the car would go into limp mode and the fan would stay running for a minute or two after I turned off the car.
When my fuel pump went bad the car would barely rev itself above 3500 and struggle to make any power
And yes this all happened to the green firebird I use to own. along with a starter arching on midlength headers, window motors going out, headlight motors and a transmission. I was very close to letting the car live up to its name
#40
You might just want to Un plug the iat sensor and MAF sensor to see if it runs better. If you have a k&n filer you could have oiled up the mass air and iat sensor so they are giving incorrect readings when compared to the coolant temperature sensor, and you can check the wire loom going to those two sensors to see if they may have gotten damaged somehow
Yeah, I had a load of problems with '95 Z28 and the terrible Optispark.
Oh, can I check for continuity at the IAT and MAF connector? How many ohms should I see?
