Shop in DFW to rebuild LT1 383 stroker
Seeing if anyone out there knows of a shop to rebuild my LT1 383 stroker in Fort Worth area do the r&r and get the motor rebuild done apparently when I had it built last time a balanced flywheel was put on instead of a zero balance which the motor was internally balanced which made it have vibration in the motor which has wore on a bearing and making noise in between 2-3000 rpm.Thanks
