Fram, what is so bad about them?
Old 05-20-2007, 10:32 PM
ckyconan2003's Avatar
Default Fram, what is so bad about them?
I hear people bashing fram filters. I;ve never had an issue using fram. Who do yall use and what makes them so greaT?
Old 05-21-2007, 12:03 AM
LS1Aggie09's Avatar
i use fram oil filters pretty regular when i do my changes and have always been pleased...kind of a randomn topic
Old 05-21-2007, 12:08 AM
bmxer8699's Avatar
i understand why he asked, there are huge debates on other forums that just bash fram to death lol, via them being made outta cardboard...
i have yet to have an issue with them, use fram superduty in the V6 firebird, V8 T/A, and pontiac GP 3.1l
Old 05-21-2007, 09:06 AM
sroach20's Avatar
cut open a fram and compare it to a wix or purolator. youll see how cheaply made they are.
Old 05-21-2007, 09:08 AM
BlackHoleSunSS's Avatar
I roll Mobil One.
Old 05-21-2007, 09:23 AM
who cares if they're cheaply made. As long as they serve the purpose and get the job done.
Old 05-21-2007, 09:40 AM
AronZ28's Avatar
I use A/C Delco.
Old 05-21-2007, 09:44 AM
sroach20's Avatar
a paper towel in a dixie cup could probably do the same.
Old 05-21-2007, 09:49 AM
thecorrectformula's Avatar
I've never used them but I've been told by many people that they basically filter too good. It may sound crazy but people tell me that the filters are to tight so they don't let enough oil flow through so they rase your oil pressure. But as always alot of people don't know what they're talking about. I personally use mobil 1 because I've always liked they're products and it seems like after I clean my oil and change the filter the old oil looks the cleanest.
Old 05-21-2007, 05:25 PM
Greed4Speed's Avatar
Besides the fact that they are card board inside, IIRC they allow the oil to bypass the filter easily. A decent inexpensive filter would be the Walmart Supertech. I prefer Wix or Delco, but have ran Supertech.
What makes them so great? They filter well, have a lot of surface area (more pleats per inch) so they restrict less while filtering better. They also have a metal plate at the end that doesn't allow the oil to bypass like the crappy cardbaord piece that Fram uses.
Old 05-21-2007, 05:32 PM
sroach20's Avatar
i used to work at a parts store back awhile ago. we got bored one day and cut open a filter from each manufacturer. i will not use fram or delco ever again.
Old 05-21-2007, 06:49 PM
bmxer8699's Avatar
then what is a good filter?? and where can i get one?
Old 05-21-2007, 06:57 PM
sroach20's Avatar
wix, purolator, mobile1, etc.
Old 05-21-2007, 07:01 PM
Krazyrat99TA's Avatar
i believe fram had a recall on their filters not too long ago beacause the insides would fall apart ....go with mobil one if u don mind spendin the money ...or if ur on a budget go with the ac delco
Old 05-21-2007, 07:03 PM
stroked383z's Avatar
i use the k&n gold filters. i like the 1" nut on the end of them it makes it easier to remove them without having to use a oil filter wrench. used them on both my camaros. on my explorer i use purolator pureone's.
Old 05-21-2007, 10:23 PM
GreenS-10's Avatar
I have used fram on mild motors and been ok. But I finally starting building motors that make some power and move some oil and kept burning up bearings and couldn't figure out why. Fram filters collapes when a high volume of oil is passed through them for an extended period of time. Soon as I cut one open and saw it for myself I switched filters and have not had a bearing issue since.
Old 05-22-2007, 07:26 AM
1970judge's Avatar
Wix filters!
Old 05-22-2007, 08:34 AM
Mike2kZ's Avatar
Mobile 1
Old 05-22-2007, 01:11 PM
osvaldo's Avatar
ive used wix, mobil 1, and the k&n, im running wix right now, but thats just cause i remeber the part number. i really cant tell the difference so there u go...
Old 05-22-2007, 02:23 PM
I8ASaleen's Avatar
WIX ???! Yea Fram would be ok for my 2.2l Cavalier, but honestly the quality is just not there to stand up to high powered engines.
