Anyone interested in a LS1 T-56 Setup?
Thinking about selling my LS1 T-56 Setup
Basically would come with:
T-56 Trans
F1 Lightweight Flywheel
Centerforce Dual Friction Clutch
Hurst Competition Shifter
Also maybe LG Torque Arm Setup
Comes with hydraulics and pedals.
Would maybe consider swaping for A4 setup. Not sure if im going to sell yet or not.
T-56 Trans
i have a built a4 with a yank ss4200 converter wanna put my car back as a street cruiser and all parts youll need to convert except the trans crossmember dont think itll fit an lt1
im willing to swap someone, i wouldnt be able to swap center console's because I have LT1 interior, unless you have LT1 console, Id need cooler lines or whatever, flexplate, and stall as well as the trans and bellhousing. I think my torque arm will still bolt up so Ill keep it. Also cross memebers id have to keep mine because LS1 crossmembers dont bolt up to LT1 cars. Oh and the shifter of course and proper linkage and pedals. I will be giving you everything needed. Serious people wanting to swap please send me a PM, you could come by and check the trans out, id like to check yours out too if its still in the car. I may be pulling it soon so Ill have everything out already. I think my setup needs a new slave though because Its engaging but not enough I think, probably just needs more bleeding, other than that I have driven it.
also, as far as wiring (correct me if im wrong) there's no need to swap wiring, because the only sensor's either trans needs i think is the speed sensor's and the reverse lamp sensor. Other than that the skip shift and stuff doesnt need to be hooked up. May have to have PCM flashed or something but other than that no big deal, + i have a 98 so if anyones car is newer than mine then swapping harness and pcm wont work either.
