Welder Questions
Welder Questions
I'm thinking of buying a welder. I haven't decided between the Lincoln or the Eastwood or the Miller. But I'm trying to decided if the 110v will suffice for what I want to do or the 220v. I'm going to have to weld on an anti-roll bar, some L brackets for a motor plate, wheelie bars, maybe roll cage. I've read that the 110's are pretty good up to 3/16 some up to 1/4. That's probably as thick as I'm ever going to need welded. Do I really need to spend the extra money for the 220 or will the 110v be adequate.
What does everybody think. If i can buy what I only need for $200 less than a 220 v machine, I don't want to spend that kind of money if I really can't use it or don't need it.
it wouldnt be bad to invest in one though, sometimes they do come handy, especially when you dont realize it.. im going to try to invest in a good mig machine.. i was pissed when i had to take my car to a shop just to weld up a pipe. i would rather do it myself and its fun. And you could also do minor household repairs and such aswell.. my 2cents
I Just got out of a fabrication school, and have spent the last 6 months behind a helmet... well you need to be a little more specific are you buying a tig or mig? as far as name brand is concerned, being that your not going to be welding for a living so i would say look at who has the best warranty. because hands down miller is the smoothest most user friendly pick up an play welder i've use and there quality is 2nd to none, same as there customer support. that being said, you know what your going to use it for, do you really need a 220 welder? in tig welders i would say go for something like a dynasty 200 is prob the last welder you would ever buy, it has an interchangeable plug that can use 110 or 220 with out any adjustments, it's very upgradeable and can be fine tuned to weld every then from aluminum cans to 3/8" steel plate. if your going the mig route the only thing i can say is don't waste your time with any of the shielded core wire B.S. go the gas route other wise you'll end up doing it later anyway, you can also get certain mig machines that you can get a spool gun attachment later and weld aluminum. . . . hope this helps
I just read this about the Lincoln 180 - "up to 3/16" with MIG welding and 1/2" with gas-less flux-cored welding". I'm no expert, but I've read that the gas-less flux core welding puts out a lot of splatter, so I would think you would want to weld with the gas shield. That line above reads to me like when using gas, you can only weld up to 3/16" which is what I keep reading is what some of the 110v do. This is where I'm having a problem.
Ive been welding professionaly for the last 18yrs. You defentally should put out the extra money for a 220 for what your looking to fab I would buy a millermatic 220 and run .035 copper flaux hardwire with and CO2/argon 70/30 mix gas its gonna give you the best out of position welds when your upside down in the car and you will never break the duty cycle. Its going to be the easiest to use and maintain Millers are top notch the only welders Ive ever bought and Ive used a ton of different brands and modles
go with the millermatic 220 you wont regert it and all your buddies will beg to use it
Those Eastwood machines are no joke. I sold my Lincoln to get the 220 Eastwood machine because I needed the spool gun. It's a much nicer unit than I expected. Super easy to setup and uses standard Tweco parts.Miller and Lincoln both make good welders, but I would recommend the 220v Eastwood for anyone running it at home
Duty cycle is not how long you can weld before the machine trips it's protection light.
Duty cycle is how long you can weld before you have to let the machine cool down.
For example... 35%... You have a 10 minute window. If a machine has a duty cycle of 35% at a certain amperage, then you can weld for 3.5 minutes straight, at that amperage. Then you need the remaining 6.5 minutes that are left in that 10 minute window for the welder to cool down.
IF you exceed the duty cycle, then your heat protection will trip and you are forced to wait for the machine to cool down on its own.
What ever machine you intend to buy... Do not plan on running the machine at max duty cycle all the time. If you do this, then you are purchasing a machine that is too small for your needs.
Eastwood is a China welder. I JUST got done giving ANOTHER China welder brand a chance. It welded, it had some cool features. I was not happy with it. I sent it back within my 30 day trial period to get my money back. Compared to my Lincoln Precision Tig 185, the arc quality was just no where near as smooth. There were other issues with the welder too.The machine came with broken parts much like every other post I had read about with other people receiving their machines in the same condition.
In a nut shell, I found out first hand that there is a reason the China welders are cheaper than the red, white and blue welders.
