Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Home Made Shop tools.
Old 02-09-2016, 06:47 PM
  #61
aluthman's Avatar
I made my own pipe beveling tool out of a repurposed Harbor Freight electric die grinder and some scrap steel. I'll be using this when I start making my turbo manifold to bevel all the joints for welding.
Still needs some fine tuning, but it should work out pretty well. I need the little posts about ⅛" higher or so and one needs to be relocated.
Old 02-09-2016, 08:28 PM
  #62
Nismo Kid's Avatar
^^^^^ That's awesome!^^^^^
Old 02-10-2016, 01:06 AM
  #63
8 Second Truck Club
Blown06's Avatar
Very cool. thanks for posting
Old 02-10-2016, 09:16 PM
  #64
rpturbo's Avatar
I really like it. I think I will do this, but modify it with some set screws, instaed of welding in the grinder.
Old 02-10-2016, 09:50 PM
  #65
aluthman's Avatar
I was willing to sacrifice a $40 die grinder to make a purpose built machine. If I never make another manifold after this one, I can always grind off the tacks to free up my electric die grinder that I will never use lol. I have an air die grinder and 2 Dremels, so I don't foresee much use for this thing other than beveling pipe.
Old 02-11-2016, 10:50 PM
  #66
truckdoug's Avatar
yeah dont use those as actual grinders. you'll go deaf before any cutting gets done.
Old 03-27-2016, 07:39 PM
  #67
rpturbo's Avatar
I used mine with some nice burrs to port my heads. It was the entire reason I got it, but now it can serve to bevel my tubes too.
Old 03-29-2016, 03:38 PM
  #68
aluthman's Avatar
I used my beveler above to put my manifold together recently. I'll probably start welding it tonight.
Old 06-14-2016, 10:41 PM
  #69
NSSANE02's Avatar
You guys have got some pretty slick stuff!
Made this a couple years ago when I had to sell my toolbox. Was my first real woodworking project.
This is my current project. Need to bend some 4' wide sheet metal to make a bucket for a front end loader I'm building. Decided to make my own press brake for it.
Old 06-14-2016, 10:51 PM
  #70
Majestic9C1's Avatar
I fabbed up an adjustable cheater bar ...
bought like 5 sections of 1 foot rigid threaded electrical pipe (3/4 inch) with couplings and slide it over wrenches, breaker bars and ratchets...
if its too long I take a piece off yada yada yada
pretty simple really
Old 06-18-2016, 12:04 PM
  #71
65drag's Avatar
Very cool invention. That is the whole point of this thread. I love the ingenuity of all you guys. Keep sharing.
Steve
Old 06-18-2016, 12:05 PM
  #72
65drag's Avatar
Now THIS is some serious home built engineering. Love the press break. Very nice!
Steve
Old 06-20-2016, 03:19 PM
  #73
NSSANE02's Avatar
Finished up the press this morning, works well so far.
Old 06-30-2016, 10:12 AM
  #74
aluthman's Avatar
That thing is a monster!
Old 07-27-2016, 04:48 PM
  #75
NSSANE02's Avatar
Finally got a full test of the brake, works great!
Old 07-29-2016, 01:55 AM
  #76
8 Second Truck Club
Blown06's Avatar
Very cool man. I see where you said it has a 4' wide capacity. How thick was that steel you where bending? At 4', what do you believe its total capacity is thickness wise with steel, stainless and aluminum?
Old 07-31-2016, 07:40 PM
  #77
NSSANE02's Avatar
The plate I bent was 1/8"X48" hr steel. I haven't confirmed any of this, but estimates put max-width-90deg bend capacities at the following:
Aluminum- 1/2"
mild steel- 1/4"
stainless- 1/8"
The new design will be top die supports of two 1"X6" cr steel plates sandwiching the die, so strength is limited to the 40T of hydraulic force at this point. With upgraded hydraulics, capacities could almost double.
Quick Reply: Home Made Shop tools.
