home air compressors
What kind and size do you guys have at your home's? I am looking to purchase one for my garage next week but not sure what size to get. Looking to use for cutting wheels, grinders, wheels on and off vehicle, drills and so forth. I don't wanna get a huge one but also not too small where it's on every 5 mins. I have looked at Lowe's and they have a pretty decent sale on them right now
I have the 30 gallon air compressor in the link below. I like that its portable so I can wheel it outside if I need to. It has enough capacity to do the small jobs that I normally do using cut off wheels, air ratchet, impact..etc. Occasionally I have to wait for it to catch up if I'm using an impact on some stubborn bolts, normally not a big deal. If I used it daily I would want something bigger, it works fine for me turning wrenches on the weekend.
I prefer the belt drive oil lubricated style compressors over the oil-less compressors. The oil-less ones are super loud.
Be sure to get some quality hose. The cheap stuff tends to not be very flexible especially in colder temps. I got some flexzilla hose from menards, stays super flexable even in freezing temps.
http://www.aircompressorsdirect.com/...FYSPMgodBg0A4g
with tools like cutting wheels you will want at minimum a 60 gal tank. I had a Ingersoll Rand 30 gal compressor at one time and yes i could use a cutting wheel with it but i would have to stop every other minute to let it catch up. slowed the job way down. I now have a 60 gal devilbiss and can use cutters and grinders and even paint with it. it will kick on after about a minute or two of grinding or cutting but it keeps the pressure constant once it does kick on. Also its not so noisy that it is annoying either.
A word of advise, buy the largest one you can afford. I've had a 60 gal, wore that one out bought a two stage 80 gal and then bought a used 80 gal tank for extra storage. that worked for a while, now I just bought a Kaeser rotary screw compressor, dryer and 120 gal tank.
Heres a trick i did. I bought a 60 gallon air compressor. By luck i got a 20 gallon air tank for nothing. What i did was ran the 20 in line with the 60. Although the motor has to run longer and made a nice difference in how long between run time and works my car hoist better too. I am really happy with the added 20 gal capacity. My neighbour who also uses my shop alot says the same. I see used tanks in the classifieds all the time. Just an option.
anyone ever hear anything bad about Quincy compressors?
I ve run a few over the years. Upright as big as you can afford is the way to go. Now I run a twin cylinder bel -air upright.......with another 100 gallon tank that is outside the shop.
60 gallon upright 220 v .........if you can or larger.
I picked up my bel -air at auction and already had the exterior tank from auction too (the tank was 5$ ...)
Moderator
My large-ish Husky just ate something between the
motor and the lung.
Have the biggest Craftsman upright in the back room,
it had developed some sort of problem with the
unloader and is waiting for me to cobble up a better
check valve & orifice setup so I can get it back on
the job (which is what the cheap Husky was bought
to do, 5+ years back). Not impressed with the
Craftsman construction, stuff like phenolic pistons
I think is just doomed (but, that's not what went out).
I have a big-*** twin lung out in the shed, for if the
original one quits (more cobbling someday).
Anything oil-less you can bet is a joke, unless you
want one dry oil-free stream for painting or something.
motor and the lung.
I dont think so. I have a older QVS 45? or somthing like that. V 2cly upright 80ga I think? done alot of with, few sets of heads but use ele now. no issues, just the head bolts came loose (other head was 1/2 3/4 turns loose?). blew out the gasket, made one from a ceral box like 3 years ago been working fine. haha. just change the oil every 2-4 years.
Putting the extra 20 gallon tank made a bigger difference than i would have thought. May wanna try it if you come across a tank for next to nothing.
I've had problems with other stuff in the system, but the compressor has never given me any issues, even with HEAVY almost constant use some days. It has plenty of capacity running stuff that most people say you need a larger 60 or 80gallon compressor, seems to still be going strong...
It's no joke.
OTOH, if I was going to replace it or if I was going to buy another I'd go with a larger vertical cast iron compressor just because this thing is LOUD.
the larger HF stuff is really good quality for the $, if I was going to buy anything reasonable right now they would probably be at the top of my list. For a while (I'm not sure that's still the case) the compressor heads were made in the US or Italy, with decent motors...
