Pneumatic Fluid Pump
I have an air compressor in my garage and I was wondering if there is a pneumatic driven pump out there that I could use to pump tranny fluid or diff fluid into their respective locations? I hate using my stupid hand pump.
Thanks folks
Thanks folks
I have not seen anything for individual quarts, but if you get your oil in 30 or 55 gallon drums you can get an air operated oil pump, but other than that you are stuck with the hand pump.
Evacuation Pump.
If you are looking for a way to take fluid out instead of putting it in, check out this evacuation pump from Harbor Freight. It costs $25 and works great. No more spilled fluid. Just push the tube down the transmission dipstick tube and suck out the fluid. No need for compressed air.
http://www.harborfreight.com/cpi/cta...emnumber=45403
55 gallon drum pump
Try this pump then. Air operated, about $60. They also have several hand operated pumps. Just search their website under "pumps"
http://www.harborfreight.com/cpi/cta...emnumber=43575
The one you linked to says "Quickly transfer oil products from 55 gallon barrels." My fluids don't come in 55 gallon barrels.
