Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Best burette fluid to use when cc' ing?
Old 09-03-2008, 04:18 PM
Gregory's Avatar
Question Best burette fluid to use when cc' ing?
What is the best burette fluid to use when cc' ing heads?
I'm thinking a light oil like hydraulic fluid.
I'm measuring the chamber, and not looking for leaks.
Thanks!
Old 09-03-2008, 04:54 PM
CTSmechanic's Avatar
Mineral Spirits....
Old 09-03-2008, 05:01 PM
cnorton's Avatar
Avoid using an oil based liquid. It will pour very slowly and adhere to the inside of the burette. Mineral spirits are fine. When I first saw it done, by NHRA tech crews, they used rubbing alcohol tinted with food coloring. I use alcohol with a couple of drops of machinist's dye to give the mixture a little color.
Old 09-03-2008, 08:27 PM
Gregory's Avatar
Kewl! Thank you very much, guys!
I like the idea of machinist blueing. I just have to figure out where to buy it locally.
Old 09-03-2008, 08:37 PM
sickss228's Avatar
Yep rubbing alcohol with some sort of dye.
Quick Reply: Best burette fluid to use when cc' ing?
