FS/FT Turbo 5.3l focus
Year: 2003
Make: Ford
Model: Focus
Price: $10000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): AL
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
5.3L ls engine. iron block. ls1 intake. modded ls1 oil pan. arp rod bolts. new rings and bearings. comp 918 valve springs.
custom turbo kit. masterpower t76 .96ar twin scroll t4 turbo. tial 44mm wg. 4" core IC. 3" ic piping
custom fuel system. aeromotive components. a1000 pump. 1-1 reg. 60lb injectors. braided stainless lines. fuel cell with drop sump and foam.
th400 3 speed auto trans. fully built. manual shift valve body. 2500 stall converter. anti balloon plate. trans cooler. hurst shifter.
8.8 4 link rearend. qa1 vertical coil overs. just serviced.
megasquirt engine management.
custom front subframe and steering. 10.8" rotors with svt calipers. 5 lug conversion. 5 spoke 17's with nitto's front and rear. 275 555r's in rear. c-notched and back halfed rearend with raised tunnel to allow for car to set much lower than krugel kit.
build thread
http://www.focusfanatics.com/forum/s...d.php?t=187379
what needs to be finished: steering attachment for knuckles (almost done). leaking brake line in rear (connected, may just be a bad line or fitting). turn signal bulbs and flasher. dyno tune. ignition switch. other than that it should be driveable.
i have all the stock parts as far as interior and carpeting go except rear seats. i will send all this with the car. body only has svt side skirts and rear wing.
i am looking to sell this car and my sti and get a c6 vette. so if any one is interested in trading their c6 for a 04 sti with 40k on it (very nice garage kept) and this focus send me a message.
thanks
tim
yeah it is a 2dr hatch. silver zx3 with svt side skirts, rear bumper, and wing.
here is a pic of it without the trans or interior. it sits a little lower now but it needs a bath. body is in great shipe no dents or dings
