FS: 1985 S10 Blazer- Tubbed, Built 355/th350, 9in
Year: 1985
Make: Chevrolet
Model: Blazer
Price: $5500
Mileage: 500
Private or Dealer Listing: Private Listing
Location (State): NE
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
This would make a fun project/toy for somebody or part it out...the reared alone was 3,195$ I simply dont have room or time for it.
Everything is fresh, only 500 miles on the build. Has some minor kinks that need to be worked out as with any car that was just put together. Runs and drives fine, pulls pretty good, but I havnt pushed it at all. Has not been raced.
Quick rundown...I have all the paperwork and the build sheet for the engine/rear-end.
Has a Blueprint engines 355 crate motor, makes 394hp.(Have dyno sheets)
-4-bolt block
-10:25:1 Compression
-.537 Int / .555 Exh & 258 Int / 266 Exh duration @ .050 - 105LSA
-2.02/1.60 valve Heads
-Keith Black Pistons
-Scat Crank
Trans/Rear
-Built TCI streetfighter th350 with 4000 stall
-Custom Currie narrowed 9in ford rear
Susp/Misc
-Tubbed, caged, 4-link set-up, 5 gallon fuel cell. Tach, water-temp, oil-press and volt gauges. Weld draglights, mickey sportsman tires all around. Pretty much gutted...
Here is a quick start/up Idle video and the pictures-
[/QUOTE]
