Western Members CA, AZ, NV, UT, CO, NM, HI
Smog test :(
Old 03-06-2009, 01:57 PM
TransAmWs601's Avatar
Default Smog test :(
So took the car in to get a smog test. I passed emissions and everything else fine, but when he did the OBD II diagnostics it looked like this.
Non-Continuous Monitors
Catalyst....... Ready
Heated catalyst..... Not supported
Eveaporative system..... not ready
secondary air system....... not ready
a/c system refrigerant..... not supported
oxygen sensor....... ready
Oxygen sensor heater...... not ready
egr system...... not supported
He said I could only have 2 that failed (Not ready).
Pep boys wanted 139 to go in and reset that... but that seems ridiculous to me. The guy said all i have to do is get them reset and he will print me the cert for 8bucks. Anyone know a shop that wont want my first born to do this?
Old 03-06-2009, 03:00 PM
Anyone?
Old 03-06-2009, 03:54 PM
bigtls1's Avatar
see if certain hand held tuners can reset them, i thought mine could. not sure tho
Old 03-06-2009, 04:17 PM
ROCNDAV's Avatar
I have a license for 02 Camaro, but I think it can clear any DTC.
I could be wrong, but it looks like they have already been cleared but just havent got enough test cycles on it yet.
Old 03-06-2009, 04:31 PM
BobDoLe's Avatar
you're right.
original poster must have cleared them before getting smogged and didn't go through all that http://www.obdii.com/drivecycle.html
or... maybe the smog guy reset them so you would fail and come back again.
Old 03-06-2009, 05:16 PM
Originally Posted by BobDoLe
you're right.
Thank you very much. Very informative.
Old 03-06-2009, 06:31 PM
ss.slp.ls1's Avatar
you're right.
Correct, you have to complete a drive cycle before you can bring it back. Drive it around for a day, normally, freeway, streets, then bring it back. It should be ready after that.
Old 03-06-2009, 07:05 PM
ROCNDAV's Avatar
If you want, I can scan it for you to see if they are all showing ready. I'm a bit up the 605 from you, but if you have no other means I can do it. It pisses me off that AZ can't lend out scan tools any more.
Old 03-06-2009, 07:20 PM
ss.slp.ls1's Avatar
Every one should have one though, it's a great tool to have.
Quick Reply: Smog test :(
