Procharged my trans am nearly 700hp
I finally got around to posting my swap. I couldnt have done this by myself, first I want to thank all of my friends on LS1tech, Haighter(C.J.), and Rob at Strictly Performance. It took me about 2 years to finish this part of the project.
I wont make the list long so here is a bit of what it consists of,
8 rib D1 procharger with a custom no slip set up from Rob
370 iron block
stock crank
diamond pistons
lunati rods
AFR 205 heads
Mezeire Electric WP
ECS Cam
Melling High Volume Oil Pump
Doug tuned the car at Strictly Performance and I couldnt of asked for a better tune, it drives so smooth. I run true duals and I drove side by side next to a cop and could shift through gears at low rpms without any hiccups.
I think Doug worked at Edelbrock for like 10 years and at Magnacharger for 5
This is what I put down, 694 HP and 598 Torque
http://www.youtube.com/watch?v=OwxW-HX61kk
370 iron block
stock crank
diamond pistons
lunati rods
AFR 205 heads
Mezeire Electric WP
ECS Cam
It is loud but it brings a grin to my face every time I gas it a bit, I just look around before I decide to drop the hammer on it, which is not often and usually on a lonely part of the highway, cuz Im not getting any traction at all till 4th gear, then it just pulls crazy!!!
1 Post
correct me if im wrong but i think stock there around 7psi and i have seen some poeple with simple mods get it to 14psi but still i dont think there even close to 700whp on a stock eaten
