Quick Question!
It should, but no guarantees. The rear hub circle sizing is different between LT1 and LS1 styles but the bolt pattern is the same... Fronts should clear no problem as long as you DON'T have a big brake kit. I mentioned the rear because some people are dumb enough that they put the spare on the back, but I hope you realize the reasoning for not putting a spare on a power wheel.
What I do then (with a simple nail in tire flat, not a shredded tire) is plug the tire with a simple tire kit, either on the side of the road or nearest exit, with a tire repair kit. Worth its weight in gold when its needed.
