Wanted Info: Wheel Adapters
more info would help
what kind of car?
what kind of wheels?
wheels backspacing? and etc...
if your going for spacers pepboys or autozone or any tire shop will have generic wheel spacers which are ok to use for a short period of time and good to use to find how much spacer you need but should never be used as a permanent solution since they are not hub centric, therefore causing balancing problems and puts a great deal of stress on your wheel studs(that should be upgraded to an longer high quality stud!)
what kind of car?
Any tire shop can get you the right size spacer, as I am assuming your using the same bolt pattern.
EDIT: from the pictures you are showing I think you can pretty much get those from ebay not sure if an auto parts store has em, maybe a tire shop and that's a huge maybe.
You need to run a 2" adapter on front and back of a 3rdgen to run 4thgen wheels. If you have a 4th gen rear end, you don't need the adapter
I got a couple of sets from ebay to get my T/A wheels on my brother's 3rdgen.
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
Btw hope this helps
for third gens:
for third gens:
http://www.skulte.com/adapterfaq.html
various rim dimensions
rim name size offset backspacing suggested thickness (3rd gen)
corvette 84-87 16x9.5 38mm 6.6" 2"
corvette 88-96 17x9.5 56mm 7.3" 2.25"
corvette gs zr1 style 17x9.5 50mm 7" 2"
corvette zr1 style (low offset) 17x9.5 38mm 6.7" 2"
corvette zr1 style (low offset) 17x11 36.5mm 7.397" 1.25" rear
corvette zr1 style (high offset) 17x9.5 56mm 7.4" 2.25"
corvette zr1 style (high offset) 17x11 50mm 7.93" 2" rear
c5 corvette 97-2000 17x8.5 front 56mm 6.8" 2"
c5 corvette 97-2000 18x9.5 rear 63mm 7.6" 2"
c5 corvette z06 17x9.5 front 54mm 7.2" 2.25"
c5 corvette z06 18x10.5 rear 58mm 7.9" 2" rear
c6 corvette 18x8.5 front (new 88967389, old gm 9594351) 56-58mm depending on where you see it 6.53" 2" front & rear
c6 corvette 19x10 rear (new 88967390, old gm 9594353) 79mm 8.11" 2.25" rear
c6 corvette z06 18x10 front
c6 corvette 19x12 rear
camaro 82-92 16x8 front 0mm 4.35"
camaro 89-92 16x8 rear 16mm 5"
camaro f1 zr1-style 17x9 50mm 6.8" 2"
camaro 93-97 16x8 55mm 6.5" 2"
roh zs 17x9.5 5 mm 5.472"
roh zs 17x8.5 -7 mm 4.5"
