swap question
swap question
A friend of mine is looking into swapping a 6.0L from a 2006 Escalade ext. And he's going to put a callaway procharger on it. He also wants to put a cam in it. Now the question is. Will the stock springs and lifters work well with a 242/244 cam.
Springs? **** NO! Time to look for a dual spring option, especially for a boost application.
Lifters, maybe, but i would seriously consider upgrading while you have them out.
What he said, I think the lifters should be fine, how many miles are on them? I would say to just pick up a set of LS7 lifters for now since they are pretty affordable and you can use stock pushrods with them, well ideally, it is still good to check pushrod length regardless just to be safe and have everything correct.
Ok. Thanks both of you I kinda figured he'd have to go with double springs. It just seems like he'd be having too much hp for them to withstand. I honestly don't know why he didn't get the whole cam package with lifters and springs I'm sure they had one. But I figure he can get a good set of lifters springs and pushrods for say maybe 400 depending
